Unit when started used to go through steps "Sensing" , then "Wet", etc. Now unit starts up at wet and stays there, never stopping the dryer. Cloths do come out dry, but dryer never shuts off. Is this a moisture sensor issue or the control board?
Hello. To test properly, the dryer must be put in diag mode--a key dance of pressing "more dry, less dry--more dry, less dry" within 5 seconds with the door closed and dryer off. All lights will be illuminated and "88" will be in the display. If you open the door and a tone is heard, along with seeing a software revision number in the display, this means that the moisture circuit is shorted. *If this does not happen*, then open the door and, using a wet cloth or finger, bridge the moisture sensor bars located on the filter holder(metal strips approx 1/2 apart and several inches long). If you do this and a tone is heard and the software revision number is seen, THE SENSOR PASSES THE TEST. If it doesn't, you're going to have to troubleshoot further with a voltage/ohm VOM meter, or better, call for service because, unless you've done this before and know what to expect, you are gonna be INVOLVED in disconnecting sensor wires and checking electrical resistances and so on. You'll have to remove the toe panel(bottom panel on front of unit) to access the sensor wires. To exit diag mode, simply unplug the dryer for about 30 seconds. One thing though, if there is a lot of lint build-up, the sensor bars could be shorted by a bunch of lint crammed between the contacts--have seen that one on occasion.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
