It's possible that the drain hose or the pump may be clogged. Make sure the tub itself is clear. You can then try removing the drain hose from the machine and see if something is stuck in it.
Also, while the hose is off, look inside where the hose attaches to the machine and see if anything appears to be stuck in the pump. You may have to service the pump as well.
SOURCE: whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
SOURCE: Duet error code F 02.
Just had this problem. Remove the kick plate in front of machine. The drain pump filter maybe clogged. Turn the white screw to remove filter, but be sure to have towels or a bucket handy. I clean mine out and now is working fine.
SOURCE: Won't drain...
on the pump there is a lint filter it is either in the drain hose coming from the tub or there is a slot on the pump that screws off.you have to take the front lower panel off to get to the pump after you take the junk out unplug washer for 60 seconds to reset computer. let me know what you find
SOURCE: i have a Whirlpool Cabrio
LD stands for Long Drain. It doesn't mean that the unit won't drain, it just means it's taking longer than it should. Any kind of restriction can cause the drain to slow. These are free steps you can follow before ever replacing any parts. Where the front panel and the top of the machine meet, there is a crack. When using a flashlight, you will see 4 items in this crack. 2 are green 2 are black. The black pieces are support studs, ignore them. The green one's are clips that hold the top to the front. Using a putty knife (easier) or a small flat head screw driver (a bit more difficult) push one of the green clips towards the rear of the machine while lifting on the top (warning they are very stiff). You can wrap the tool in a light cloth to help protect the finish, althought it may make the clips more difficult to remove. Only lift slightly (too far and it will bind on those support studs I told you about) Now press the clip on the other side and lift the top up.(now this is easier if you have a second person to hold up the lid while you work underneath. You will see your tub from a new perspective. First you will see a plastic ring around the top of the tub. Disconnect the green clamp on the hose towards the left rear using a pair of pliers or channel locks. The ring is held down with clips all of the way around the tub. By pressing down over each clip and pulling the clips slightly forward, you can remove the top ring. The rest is the easiest part. In the center of the basket, there is a small cap. Remove this with a small flat head
screwdriver. Remove the bolt (7/16") that is underneath the cap. Now lift the whole basket out. If your small items get too far (ie, the pump), remove the back panel. On the left hand side you will see a small black hose towards the botom. This connects to
the pump. Forign objects can lodge in here keeping it from draining also. If you disconnect the hoses, have something handy for all of the water to go into (large wet vac is usually the best). Drop the 3 #20 torx screws and the pump will come down
and you can remove the obstructions. Remove the drain hose (the thicker black hose from the back of the machine) out of the wall. Now re-insert it back in only 6" going into the drain. When they go in too far, the drain in your house that prevents odors from coming back out of your drain can cause a problem. Make sure to tie the drain hose down with a tie so it does not pop back out when the washer is draining/ spinning.
SOURCE: ERROR NOT DRAINING
the filter is located right after you open the drain cover on the bottom of the washer it's a hard plastic filter, if it is not clogged with any debris, then it sounds like your pump motor is bad, maybe need to replace it. lg's are very sensitive........., find out the part number and search it through google. if not email me and i could set sumthin up for you.
[email protected]
dave
