Knowing the beep pattern will help diagnose the issue. Power on the computer again and listen for long beeps and/or short beeps. There are other possibilities, but if you just cleaned out the computer, I suspect you might have dislodged a memory stick. Make sure they are seated completely and the white tabs are locked securely in place. The beep code you hear will ultimately help determine where the failure is happening.
SOURCE: Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
SOURCE: I just installed this royal
yes there is a diod in the fan its like a fuse but smaller if you open the modules in the fan you may see a diod burnt or dicolered this does happen alot these control differnt parts of the fan light fan itself, good luck
SOURCE: took floor fan apart to clean, cannot remember how to put motor part back on
www.laskoproducts.com
Write to the company and ask them?
Hi Anonymous, I want to help you with your question, but I need more information from you. How many beeps was it and did the power button blink aswell or no?
