I KEEP GETTING A BLACK SCREEN THAT SAYS WINDOWS ERROR RECOVERY OVER AND OVER IT KEEPS REDOING THE SAME THING NO MATTER IF I CLICK LAUNCH STARTUP REPAIR OR STARTUP COMPUTER REGULAR THEN A SCREEN THAT NAMED STARTUP REPAIR POPS UP AND SAYS WINDOWS CANNOT REPAIR AUTOMATICALLY ITS LIKE ITS STUCK ON REPEAT I NEED HELP BAD PLEASE
Hi Tiffany,
it sounds like there has been some sort of corruption of the files on the hard disk. You should see about booting from the Windows installation CD / DVD and copying all the files that are of importance to you (documents, photos, music, etc.) on to an external hard drive connected to the USB port or installed as a slave drive internally. Once you have saved all the files you need, shut off the PC and disconnect / remove the drive with your files. Then reinstall Windows again. Once done, shut off the PC and reconnect the drive with your files and copy them back to the hard drive and you should be good to go unless he drive is beginning to fail - in which case purchasing a new hard drive would be a good idea.
SOURCE: my sons dell e520 wont
Have you tried to put a disk in the floppy drive when it starts up?
It probably had a disk in before last close down, and is looking for it now when you start up.
Please vote if this was helpfull :-)
SOURCE: dell optiplex gx280 keeps rebooting after bluescreen
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
#1: Use a Windows startup disk
#2: Use Last Known Good Configuration
#3: Use System Restore
#4: Use Recovery Console
#5: Fix a corrupt Boot.ini
#6: Fix a corrupt partition boot sector
#7: Fix a corrupt master boot record
#8: Disable automatic restart
#9: Restore from a backup
#10: Perform an in-place upgrade
SOURCE: Black screen
Hi I can understand your problem.
It seems more likely to be an issue with video card drivers. I'd suggest you to go for ADVANCED MENU and go to Last Known Good Configuration..
If still it didn't work go to enable VGA mode and try increasing the resolution rate...
That should work.. If not kindly revert with an information..
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Hope this helps
