My monitor is show no signal analog.is it problem with the cpu or problem with monitor?
Can you still see the boot up screen when you start your machine up?
If you do, then restart the system.
As it's booting up, you tap F8 until you get a menu. Select "Last Known Good Configuration". That will help if you installed a bad driver for your graphics.
If that doesn't help, or if you don't get a picture at all, plug the monitor into another computer and see if it works.
If the monitor works and you still can't get a picture after following the aforementioned steps on your computer, you may need to replace the video card on your system.
When i turn on the pc it says stromsparmodus. I have checked the cpu works otherwise and the monitor works if seperated form the cpu. what do i do
SOURCE: Hi My Samsung Sync Master
Hi There,
This problem often occurs on the LCD monitor, please read my tips to fix this problem, just click here
regards,
dm
