Question about Panasonic NN-T945SF Stainless Steel 2.2 Cu. Ft. Countertop Microwave Oven
What would cause the fan and turntable on a Panasonic Inverter microwave to run continuously when plugged in with the door closed (and not turned on)?
I just replaced the door latch because it was broken, but now when I plug it in the fan comes on and the turn table rotates inside with the door closed. When I enter time and start the microwave the light comes on and seems to be working fine. If I push the stop button, the fan and turn table continue to run. When I open the door the fan and turn table stops and the light comes on. If I closed the door the fan and turn table come back on. I have check the door switches and all three have continuity and seem to be engaged and disengaging properly when the door is closed and open. Any ideas what could be my problem?
  • Brad
    Brad Aug 09, 2015
    I have check all three switches for continuity. The primary and secondary switches have continuity when activated/closed. The short switches has continuity when it's not activated/open and no continuity when activated/closed as it should. I have checked all of the switches when the door is open and closed and they are all functioning as they should, at least as far as I can tell. I read somewhere that is could be a relay switch problem on the circuit board. Could this be it?
    When I plug the microwave in with the door open, the turntable starts to turn, but then it stops after less than a second when I hear a little click from the circuit board (I think from the relay switch).
  • Panasonic Master
  • 10,543 Answers
The door switch is adjustable. one or more need adjusting to solve the problem
Posted on Aug 08, 2015
6ya staff
SOURCE:
Troubleshooting- microwave turntable and fan run constantly when door closed, door switches test good, timer can be set and oven runs otherwise; need amana microwave ACM1580AS wiring diagram
I'd look for a defective relay or shorted triac on the control panel circuit board. Either could cause this problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 24, 2015 | Amana Microwave Ovens
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
Panasonic inverter microwave: when i shut off the lid, turntale automatically rotating
When you close the door the turntable comes on? Almost all have a safety switch in the side of the wall where the door closes, An inspection inside the unit will show if switch is damaged or out of position which could cause this problem.
Dec 17, 2012 | Panasonic Microwave Ovens
My Microwave continues to run unless door is open. I do not think it is heating though when I shut the door. When I close the door and push buttons nothing happens. I get a high pitched sound when I...
The high pitch sound to me may be coming from the speaker on the main circuit board. Try to unplug for a few minutes, reset clock time and then try again. If same issue, may need new PC board. When you say Microwave continues to run are you meaning the Turntable is turning and the fan running?? Or is it just timing down. Almost never does it actually keep heating. On GE units I mostly find bad door switches will cause a back feed and make the tray turn and the cooling fan for the mag to run. To see if that is the problem You have to look at the door switches behind the front panel on the left side and see if any of them have any browned connections on the terminals where they push ontl the back of the switch. That will cause the fan and turntable toi run, but wouldnt cause a high pitch squeal. These companies use switches wtih small 3/16 terminals that dont give a good enough grab on the switch, they get loose and hot and make the switch go bad. I replace that switch with a switch with 1/4 inch terminals and runa short section of Hi temp wite to it and it wont go bad again. Just cheaply made!! Also I guess the squeal could come from the turntable motor area. So By fixing the switch problem it could fix your squeal. With nothing else running you may be able to hear motor and coupling noise you couldnt hear before.
Aug 17, 2017 | GE XL1800 1100 Watts Microwave Oven
Turntable and Fan won't stop running when door is open.
With the model number, we can offer more specific advice or an estimate.
But since FixYa does not notify us of follow-ups, you will need to post a new help request.
May 31, 2010 | GE JE1640 Microwave Oven
Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Mar 12, 2008 | Panasonic NN-T993SF Microwave Oven
Fan runs and turntable turns when door is opened
SRUte- This sounds as if you have a collapsed door switch, this would cause this problem,I would not recommend using it until repaired. But as far as recommending a good brand,each to his own everyone is different.I have done repairs for years,and I Love Panasonic products,they seem to have minimal problems.I hope this helps you out. cooltek Mar,3/08
Mar 04, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
My microwave continues to run, (turntable and exhaust), when the door is opened.
all microwaves have 2 safety switches at least... but these are tied to a set of relays that turn it on, my bet is a sticking or stuck relay because you unplug it right and plug back in its not running?-relay ... if always runs driver transitors.
Dec 27, 2007 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-T945SF Stainless Steel 2.2 Cu. Ft. Countertop Microwave Oven Logo
516 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
