Cant boot but can get to command prompt window
To access the System Restore Gui from command prompt you will need to type in rstrui.exe
OR
%Windir%\System32\rstrui.exe
Other Thoughts
If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
I think this article will help you: How Can You Restore Your System to An Earlier State Uufix Security How to...
How to perform a System Restore using Command Prompt? (ransomware or virus is blocking Safe Mode)
The System Restore function restores operating system files to an earlier point in time. System Restore is useful when malicious software infiltrates a computer and damages the system files. Moreover, this function important when dealing with variants of ransomware infections that block computer screens. This tutorial describes the process of performing a System Restore using Command Prompt. In some cases, especially when dealing with ransomware infections, performing a System Restore is a complicated task, since modern fake antivirus programs and ransomware infections are capable of blocking an operating system's Safe Mode and Safe Mode with networking. This leaves one solution: performing a System Restore using Command Prompt.
To perform a System Restore using Command Prompt:
1. Start your computer in Safe Mode with Command Prompt. During the computer start process, press F8 key on your keyboard multiple times until the Windows Advanced Options menu appears, then select Safe mode with Command Prompt from the list and press ENTER.
2. When Command Prompt Mode loads, enter the following line: cd restore and press ENTER.
3. Next, type this line: rstrui.exe and press ENTER.
4. In the opened window, click 'Next'.
5. Select one of the available restore points and click 'Next' (this will restore your computer system to an earlier time and date).
6. In the opened window, click 'Yes'.
Turn off the computer, then hit the power button to turn it
back on and immediately start hitting the F8 key repeatedly until you see SAFE
MODE. Take the Safe Mode option and let it boot up. Safe Mode will look
different to you, the screen will be darker and the icons bigger, this is
normal.
To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
You can try to get to a dos command prompt or you can see if the
system will allow you to boot in Safe Mode to get to the dos command
prompt.
