It needs servicing by a Technician- often times say it only needs belt but you can replace belts and still have the same problem. The dried lub has to be removed and new fresh non- degrading grease needs to go in and then it will work. Dual cassette decks are usually not worth the $200 it will take to work on two mechanisms. You might find a $10/Hr technician but I doubt it.
SOURCE: Kenwood Dual Cassette deck KX-97CW runs fast
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
SOURCE: Dual Cassette Deck won't stop or auto-reverse
My Tascam 202 wr need to replace belts on recorder of duel deck? what is the best way
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
SOURCE: I have a Kenwood KX
The flywheel belt would have broken or gone slack and fallen off the motor pulley. You can confirm this by opening the top and looking inside. If you can shake the machine holding it upside down the belt might even fall off.Replacing the belt is a tricky job. Its like putting back a bicycle chain except there is a metal plate behind the flywheel and your hand won't go there.
Testimonial: "Thanks, so much for your reply. Might you know of a repair place in NYC?"
SOURCE: Sony TC-138SD cassette deck starts
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
