Fossil VT2657 Pocket Watch Logo
Posted on Jul 12, 2009
My Fossil VT2657 no longer works. I can see no physical damage, but it hasn't been used in years. I'm not even 100% sure how to wind it, but after quite a bit of winding in both directions it still doesn't function. Suggestions?
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Jul 13, 2009
Anonymous
Contributor
Level 1:
Answers
26
Questions
0
Helped
17022
Points
56
It has a battrey or and atomatic winding gear. watch makers a stoped self winding watches due to people over windinfg and braking the watch. check battery it might be dead. or just shake the watch back and forth untill it starts again
What kind of battery does a Stark PH-1114 take?
I have no idea what type, ...but having just replaced a battery for that exact watch, you have 2 options:
1.) Mail it into Fossil (cost is $18.50) you can download & print repair form here:
http://www.fossil.com/attachments/en_US/watch_repair_form.pdf
2) Physically take it into any Fossil store in US or CANADA where they can do it there on site, for $10.00 even.
Hope that helps! ;)
Fossil twist
If you do not wind the watch, and if it is electronic it obviously has a battery. Very possible even with a new watch the battery has run out. This is especially if the watch was sitting for about a year in their inventory before you bought it.
I am not sure if your watch has a kinetic type movement where it charges the watch, or it is purely an electro-mechanical type movement. I did read it has a quartz referenced movement for the mechanical balance wheel. This would certainly involved a battery. If changing the battery is not the fix you would have to send the watch for service.
1helpful
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
I OWN A FOSSIL WATCH MODEL #ME1044. IT SIMPLY STOPPED WORKING. I BOUGHT IT 8 MONTHS AGO AT ROSS. THE HANDS DO NOT MOVE AND THE WATCH DOESN'T SEEM TO BE STORING ENERGY FROM PHYSICAL MOVEMENT. WHAT DO I...
replace the battery? otherwise send it to fossil. regardless of where you bought it it should have a limited 11-year warranty as as i can tell.
http://www.fossil.com/en_US/shop/customer_care/static/fossil-warrantyRepairs.html
Free roaming second hand
This sound like a job for the professionals.
I advise you to take it to a watch repairer.
Can't get back off to change battery, even with special tool
Looking at the Fossil site, I couldn't find "Arkitekt blue" as a description.
I noted that they have a blue one which is automatic (i.e. self winding) and therefore does not need winding - but it does need to be worn to keep the spring wound up.
The Fossil site has a complete list of their models and selecting one gives you all the details of the watch, including manuals.
I suggest you try a search on the web site.
1helpful
My watch no longer functions even after winding.
I have found that some of these "automatic" Fossils also contain a battery. That is how that provide an automatic watch at such a cheap price. I recommend taking it to a jeweler to have them check this. If it needs repair it will likely cost near the watche's replacement value.
Fossil AM-3662
It has a silver cell button battery, type 371 or equivalent.
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
