Hi Barry,
I think that you will find that the TV is secured to the wall mount by a number of screws/bolts which pass up through the "shelf" and into holes which are moulded into the base of the TV. Removing them should do the trick. However, make sure that you disconnect from the power outlet. Also, depending on the TV, weight can be a problem. Make sure that the TV is supported while you release it from the wall mount. Get a second person to help.
