Nokia 6300 Cellular Phone Logo
P
Prayag Posted on Aug 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display with black Spot in center and irregular lines Up & Down
My Display has a black Spot in the centre and there are some lines up and down of screen. Recently i changed my charging pin socket. After 1 month this problem arised. Help me solve out this issue. Thanks in advance
Sean Bailey
Level 2:
  • Expert 81 Answers
  • Posted on Aug 04, 2015
Sean Bailey
Expert
Level 2:
Answers
81
Questions
0
Helped
20972
Points
158
Your display is damaged from pressure. Something put enough pressure on the center of your screen that it touched the LCD.
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
[email protected]
1helpful
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
E
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
LCD screen has irregular lines and black spots but
Pls. be awair that if you do attempt to fix it by yourself the manufacturers warranty might not cover for any future problems.
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
1helpful
Screen Problems with HP laptop
i think it is under of waranty. it look likes your graphic card or emmeded chip is down. need to get service.
2answers
Sanyo PLC-XT16
Hi there
Is there any on screen prompting ?
If not , open up the lamp door at the bottom and take out the lamp. Check on the lamp's shaft for any irregularity ( i.e. vein like looking black marks or bubbles or a white spot , also check that the fillament on the inside is not broken.)
If you spot anything I listed up here , your lamp will need replacement.
If you cannot see any irregularity , check when the unit shuts down which of the LED's on the unit flashes.
It will either be your lamp or the Ballast ( lamp's powersupply ) that is faulty and will need replacement.
2answers
Black line down the center of screen
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info ctechnicians.com
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
