I have reinstalled the software, and reset the printer to factory default. It is still happening. It just started to do this today after months of perfect printing. I have printed status reports and that seems perfectly fine, but the Test Page is also printed in with a blue tint behind the text
SOURCE: Printer prints test page each time printer is turned on
I had this exact same problem, except my printer is a HP PSC 1315v. I did as was suggested (also just like it says on the printed test page), scanned the test page and it SOLVED my problem. THANKS!!
SOURCE: HP F4180 Printer printing small
Hi Lady Luxe,
Try running the Manual Uninstall solution (click link below):
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00501015&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Then run the HP Installer from your disk (v. 8.0). You may want to also restart your Mac after installation is successful (make sure you complete the Setup Assistant - don't skip it!).
Try to scan from the glass scanner bed to see that your connection is solid. Try to print now and it should be fine.
David E.
SOURCE: hp psc 1510 won't print
did you check if the printer online? did you check if the printer cable is ok?
SOURCE: HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
