Hey Tara, I understand that your Frigidaire Top Load Washer is squealing and presenting a burning smell. Is this occurring every time you are using the washer or with random loads? Typically, when you experience the squealing and burning smell it indicates that the washer is possibly overloaded.I would recommend that you stop the washer and reduce the load.If the problem persists, please reach out to a professional technician.Hope this helps! -JK
I had a similar issue, had a bad bearing. A quite frequent failure int this device. Only way to diagnose is dismounting it
These are not properly your model but see some videos how to do it:; might help to understand the job
The belt has been ruined. Basically there was to much load on the belt. You will need to replace the belt, maybe a 20 dollar fix and should take no longer then 15 minutes. Just make sure that before you go to the parts house, your remove the old belt and take it with you along with the model and serial number of the machine.
