SOURCE: Could Anyone Tell Me, How To Unlock Region Free A BDP-S300 Player??
http://www.stegen.com/product_info.php/products_id/1019?osCsid=daccaf0338a597dd1985e0ad70ac277a
SOURCE: Need To Unlock My Sony BDP-S500 To Play Imported DVDS And BLU-RAY
I don't think that it is illegal to change the region of a DVD player as a DVD drive in a computer can be changed easily up to 5 times before they are locked on one region. Sony Blu-Ray players at this point don't have a hack code and they have to have a hardware mod to play both region A and B Blu-Ray discs. There are inexpensive Phillips DVD players that are region free or they have an easy method to make them region unlocked. I don't know of any Blu-Ray players that have that feature, but you can get a N. American region coded player that will play both PAL and NTSC, but you will have to use a voltage converter as N America is 120V 60Hz and Europe is 220-240 @ 50hz.
The other option is to get a Blu-Ray/DVD RW drive for your computer and set it as a region 1drive and connect it to the TV for playing US discs.
There are other things you can do but those ARE illegal or questionable and I can't post them here.
Best of luck
SOURCE: i want to unlock the region on my samsung bdp 1600
Not sure of this works on the very latest models but here it is :-
1) Press the POWER button on the remote to turn on the
machine (no disc in the tray).
2) Wait till the player has booted up and the Samsung logo
screen is displayed.
3) Press the OPEN/CLOSE button on the remote twice, to open
then close the disc tray.
4) As soon as you see "No-Disc" displayed in the top left
corner, press the REPEAT button followed by the 5 digit code
for your current region as listed below.
(Mine was 57538 for region 2)
Don't press the REPEAT button for too long, just smoothly
press REPEAT 5 7 5 3 8.
If it doesn't work straight away, keep trying, mine worked
on the first go.
5) If you're successful, your current region code will be
displayed in the top left corner of the screen.
6) Press '9' to make your player region free.
7) Turn the player off, then on again and test with a
different region disc, or if you don't have one to test
with, just repeat the hack and instead of your old region
code appearing in the top left corner of your screen, you
should see '9' if you've been successful.
The hack can be repeated to turn your machine back to it's
original settings or to a particular region if the disc is
sensative to region free machines.
Region Codes
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
