It is an old AS60 model, but was working well when I left the house. Now no buttons work and I had to unplug to stop the noise.
SOURCE: "F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
SOURCE: FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
SOURCE: F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
SOURCE: Onkyo Rec(R-805X)does not work-constant clicking when plugged in
i have a similar problem, i plug it in and let it click to its hearts content, it will speed up to a very fast rate then slow down and eventually stop... then the unit will work fine for a couple of days but the clicking will return its not a permanent solution but it works
SOURCE: I'm getting a constant beeping sound and a F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Testimonial: "thank you for such a quick response! On my unit it is a STOP/CLEAR button but it only stops it for a minute, so it must be the touch pad. *sigh*"
