Sylvania LC420SS8 LCD TV Logo
B
Betty Jo Penny Posted on Jul 30, 2015
How do I change from a cable input signal to an antenna input signal on a slyvania TV
Model number 6413TD
I cannot change from the ATV to the DTV. ANY clues on how to do this??
Got to know the model number of your tv. If the set is only atv then you would need a decoder box to convert digital signal from antenna or cable company to analog channel or to composite input on the tv.
2answers
When i mak the automatical programin for my tv (toshiba model no. CN27H95) it find nothing!!!! so there are others ways to mak manual programing to find chanels?
This feature is pretty reliable and the lack of channels may be due to the lack of signal to the set.
You must have either an antenna, a cable from a cable service or a satellite receiver connected for the set to find any channels.
Set top box
If you are using only an antenna (digital tv) with no other company involved (cable dish, etc) you do not need any additional boxes to get the digital signal as the tv has a DTV input. All you need is connect the antenna, switch the tv to that input number, then use the remote to go into the settings area, change the antenna type to digital, then run a scan to find all available digital signals in your area. You should be all ok now!
Good Luck!
Rich Lilja
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
When I hook my tv up to cable I get no signal, if I just hook it up with antenna it works fine. How do I get my tv to work with my cable cord? Would be nice to view cable channels instead of just 3...
nialbert,
It sounds like you are hooking the cable to the wrong input (digital instead of analog) or you do not have an analog input. If you do not have an analog input you could run the cable through a VCR to convert the signal to a separate audio/video signal and send it to the TV via an auxillary input. Without the model number I can't give you much more help.
Thanks for using FixYa and for the great rating.
hardrocko
We are using an antenna as an input signal instead of cable and we can't find where you adjust the input signal to antenna instead of cable to the display.
Can you please provide further details of:
  • Cable provider
  • Make and Model of your TV you are connecting to.
  • Was the Cable connected to the antenna input, or was it connected to a decoder/set-top box.
Thanks
Isaac
2helpful
Turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. [email protected]
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
2answers
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
