Washing Machines Logo
S
Sharita Casey Posted on Jul 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Owners manual for sears kenmore washing machine type 588-08 model number 110-21102011
How to remove agitator assembly
Level 3:
  • Kenmore Master 6,687 Answers
  • Posted on Jul 31, 2015
Cindy  Wells
Kenmore Master
Level 3:
Answers
6687
Questions
0
Helped
3529376
Points
21743
Many Kenmore appliance manuals are available from the Sears Parts Direct site: http://www.searspartsdirect.com/ . The manual page for the 110.21102011 washer is http://www.searspartsdirect.com/partsdirect/user-manuals/11021102011-Kenmore-Parts-Washer-Parts-manual?searchTerm= if you want to read it in your browser. (A PDF plugin is needed.) The direct link to the manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/1009787L.pdf if you want to read the document in your PDF reader software.
The parts diagrams may be more useful for how to remove the agitator. Those are available here: http://www.searspartsdirect.com/kenmore-parts-washer-parts/model-11021102011/0582/0153200.html?searchType=modelSearch&prst=&q=11021102011&searchTerm=11021102011&shdPart= . The agitator is shown in the Basket and Tub Parts diagram: http://www.searspartsdirect.com/kenmore-washer-parts/model-11021102011/0582/0153200/K1103004/00003.html .
I hope this helps.
Agitator broken off in top load Sears 300 washing machine..i have manual from purchase noting model 110.2234/2244. where can I get replacement part.
That isn't a complete model number. I found three models at Sears Parts Direct that started with110.2234* . Click on the Models tab at https://www.searspartsdirect.com/search?q=110.2234 . The three machines use the same parts. The parts diagram for the Kenmore 110.22342511 top load washer here: https://www.searspartsdirect.com/model/3219xhjolw-000582/kenmore-11022342511-washer-parts . The upper agitator is given a different number on the basket diagram for some of the models. However, the current replacement is part W10836692. This is back-ordered at Sears Parts Direct. It's listed as in stock at https://www.maytagreplacementparts.com/PartDetail/Upper-Agitator/W10836692/4363274 and https://www.appliancepartspros.com/whirlpool-agitator-w10836692-ap5988691.html .
Kenmore manuals almost never list the full model number. They make one for several models in a line or multiple lines. In this case, the manual covers two series: 110.2234xxxx and 110.2244xxxx washers. 110 means that the machines were made by Whirlpool with the Kenmore nameplate. Manuals Lib has a copy of this manual here: https://www.manualslib.com/manual/1327493/Kenmore-110-2234-Series.html . In the future, you can usually find the model number in one of several places on the washer. Check for the label on the back of the control panel, on the back in the upper left corner. or inside the washer on the frame under the lid for a top-load machine. There are a few other spots where the label could be but those are the most common. I hope this helps.
2answers
I have a kenmore heavy duty 80 series top load washer model 110 and it is no longer agitating. I think it is the dogs that need replacing but the white portion of agitator itself looks a little worn. ...
well i would recommend repacing agitator and agitator doggs ... get complete model number off washing machine data place got to sear.com and select partsdirect enter model and order parts they will send directly to you...
2helpful
I have a Kenmore 110. (full number is 110-82984810) It has a "ratchet/screw" type agitator. The big fins on the bottom part agitate back and forth, but the center piece no longer moves in a...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082984810/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
For future reference you might also want to review / print / save the following Whirl[pool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
How to take out the agitator
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following:
This is a description of how to replace the "Agitator dogs" but it also shows how to remove the complete agitator assembly.
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.
Following is a procedure for removing the agitator(s) on top load washers.
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
I need direction how to remove Kenmore washing machine clutch
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=a90e77f262530006e64486ae2d6f5699
NOTE:
You don't have to remove the agitator(s) to get to the clutch.
You do have to take out the bolts that hold the agitator(s) to the main spin shaft inside the drum. The main spin shaft is part of the transmission.
You also don't have to remove the Spin Tube and Brake assembly.
It is a lot easier to remove the transmission if you lay the washer down on its' back.
2helpful
My new Kenmore 400 top load washing machine terribly noisy.
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
I have a Sears Kenmore Washer model 110 4564191 and cannot remember how to remove the agitator (manual is lost). The agitator is jammed likely with a sock.
36helpful
4answers
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
5helpful
4answers
Sears Kenmore 80 series washing machine Model 110.26832691
How do you remove the top of a kenmore washing machine? I have a mouse stuck in the lid and can not get the top off.
Alexander
vince
