Where is the spare storage ? On the phone or on the memory card?
The phone doesn't use the memory card to store messages it uses it's own internal memory storage. If you have saved items there then this may be why it's running out of space.
It senses an error or problem and shuts down. Try disconnecting all the cables and wires attached to it. Try it again. If it still shows protect message, it is an internal fault and requires a repair shop. If it clears up, then the problem may be a shorted speaker wire. Correct the short when reconnecting the speakers.
This is an international symbol on the start of area codes. IE I live in Australia ans text messages received from other Australian mobiles have +61 which is the AUS international area code. If you replace the +61 with a 0 (in the case of AUS text messages) this is now the full mobile number the text was received from. Hope this helps.
This is an error message generated by one of Faircom's products. Their web site is faircom.com. I suggest contacting them about the error message in order to get specific advice for resolving this issue.
That's a problem the Network Service Provider should be able to solve. I don't think it's your phone.
Remember to delete msgs, when you no longer need them. The phone only has a set amount of memory. Phonebook
500 x 16 fields, Photocall Call records
20 dialed, 20 received, 20 missed calls Card slotmicroSD (TransFlash), up to 2GB, 64 MB card included
- 6 MB internal memory
The only time that happened with mine was when the internal memory was almost full. Try moving some stuff to the memory card. those phones only have about 5MB of internal.
If that doesnt work then your phone is not unlocked for internet and mms use. You could be paying for the service and your phone isn't set up for it. Only your carrier can activate it unless you know how to hack it.
Or, you could be just outside the GSM data coverage area.
