It is icing up and when it get build up enough the evaporator fan blade will hit it and make a hell of a noise I have to de-ice it like every week but the frig and freezer they work good except that so does anybody have any ideas
I still believe your problem is with your defrost heater or defrost thermostat not the defrost timer. Pull the two leads off the heater and ohm it out with your ohm setting on your multi meter .put it on the sound setting as this will be easier,you should get a beep if its good,now look at the thermostat thats connected to the evaporator and see if it is raised up - normally it will be flat.
Testimonial: "Where is the evaporator at is it underneath in the back and my frig is model no SS25AFXMQ00 THANKS ALOT FOR THE HELP"
Your evaporator should be inside the freezer behind the back wall panel,remove the screws and pull out the panel,(you may want to unplug the unit while doing this)The evaporator is the silver metal device and your defrost heater will run underneath the evaporator and up both sides about 7-8" or so. ( it's a "U" shaped heater. Remove the ends off and test the leads on each end of the heater and listen for the beep as I described before. Good Luck!
I suspect that the door seals are not as they should be and allowing air into the compartment bring in humidity that is turning to ice
