Cameras Logo
Peter butti Posted on Jul 27, 2015
How to reset Lumix gf3 camera back to factory settings
tollertoller
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 14 Answers
  • Posted on Dec 21, 2018
tollertoller
Contributor
Level 1:
Welcome Back:
Answers
14
Questions
0
Helped
5000
Points
25
The users manual is available free at the link below. Search for reset in the PDF file. http://help.panasonic.ca/viewing/ALL/DMC-GF3P/OI/vqt3q95/vqt3q95.pdf
Hope you can make the camera work the way you prefer.
2 Related Answers
SGNath
Sujith Gopinath
  • 170 Answers
  • Posted on Feb 04, 2009
SOURCE: I would like to know
Press the Menu/Set button and from the Setup menu, select Reset.
Anonymous
  • 6771 Answers
  • Posted on Apr 05, 2012
SOURCE: how do i factory reset my panasonix lumix dmc-fz45
Remove the batteries for 60 seconds, at the same time press power and hold for the juration of the time, this will remove residual voltage and reset the processor ic, "long shot" if no change the zoom part of the lens is malfunctioning, the zoom motor or gears are jammed.
My DMC-GF3 camera states to turn on and off the camera but I can still take photos. I can turn it on and take the shot and after that the prompt comes on to turn the camera off and on again
You have a software or hardware issue. The software has a glitch or the shutter motor is causing an overload or perhaps the focus motor. Go to Panasonic website and download the latest firmware and update it to eliminate the software. Also try reformatting the SD card.
1helpful
Reset to factory settings - what does 'reset file no' mean?
"Reset file No." is the reset for the numbering system on your file folders only. You want to use just "Reset" which will reset the entire camera back to factory settings.
Factory reset Lumix DMC-FZ45
Remove the battery for 20 mins. replace the battery.turn on and go to the camera's Menu scroll through the settings to the Date & Time, set the current date and time.
1helpful
Can anyone help me turn off self timer LUMIX gf3
Press the cursor that has the clock and burst symbols. You should be presented with multiple modes. Choose single to take normal shots without the timer.
Reset lumix DMC-GF3
hi my grandaughter has a lumix gf3 when she turns camera on the
screen is nearly black if you turn to the light it says a problem with the lens connections have tried another lens but the problems remain. any ideas would be grateful regards mike
How do you change language setting on a panasonic lumix DMC gf3 from japanese to english?
how do you change language setting on a panasonic lumix DMC gf3 from japanese to english?
Can't download photos from my lumix gf3 camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto, Windows Photo Gallery, and Picasa.
Jan 27, 2012 • Cameras
I want to reset my lumix panasonic fs16 but afraid of what it will do to my camara
It will reset the camera setting back to the factory default settings the camera came with.
7helpful
How to reset to factory specs??
Enter the SETUP menu and select RESET. You'll be prompted to reset two sections. Answer YES to both and everything that can be set to default will go back to the factory default state.
Top Lumix Cameras Experts
Ngoro
SmartAviator
SmartAviator
Are you a Lumix Camera Expert? Answer questions, earn points and help others
