Canon PIXMA MP495 InkJet Printer Logo
Chymeri nhja Zoskja Posted on Jul 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does all-in-one printer Canon MP495 keep showing up as 'offline' when all connections and cables are secure and PC can see printer?
This printer has been connected to a Windows 7 PC using USB. Although all drivers, etc., are up to date, when I try to print the message comes up as 'Printer is offline'. Occasionally it will work for a few days, but keeps letting me down when I need it. Any suggestions on how to get it back to normal before I send it to the recycling? [Update] Printer was recycled and replaced with Epson, which has given no trouble so far, and makes better quality prints.
  • Edward K Lee
    Edward K Lee May 17, 2016
    Sounds like a bad cable. Try a different cable.
  • Chymeri nhja Zoskja
    Chymeri nhja Zoskja May 17, 2016
    Already tried that - we are the house of cables. In the end I gave up and bought a new printer (Epson) which has performed without issue for about nine months now. Will be steering clear of Canon in the future.
Claude Kayser
Level 3:
Top Expert:
  • Canon Master 9,098 Answers
  • Posted on Jul 26, 2015
Claude Kayser
Canon Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061527
Points
28436
Canon mp495 printer offline error.pdf - WordPress.com
https://tumulcozi.files.wordpress.com/.../canon-mp495-printer-offline-err...
the printer model to remove and select 'MP If an error message appears or if you ...computer keeps saying mu wireless canon printer is off line If you feel any of ...
Wefix365 Canon
Level 2:
Habit-Forming:
New Friend:
  • Expert 19 Answers
  • Posted on Aug 10, 2016
Wefix365 Canon
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
19
Questions
0
Helped
23485
Points
112
If you have any kind of problem regarding canon printer then you can call at 1-888-924-2961 toll free number anytime for canon printer support or visit this website that can be beneficial for you. http://www.wefix365.us/support-for-canon-printer
    Chymeri nhja Zoskja Aug 10, 2016
    I got rid of the bad Canon printer and replaced it with an Epson one, but thank you.
I have Canon TR4527 printer, 1303 error message keeps showing and there is no jam. help please!
Please remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
If the printer shows a jamming error then check the input of the paper feed as there can be some foreign objects that is obstructing the detector opto-coupler or the detect switch. clean and check or the sensor is faulty.
Printer is on, but on my computer it says that its offline
put it online in your printer attributes, set it as default. Connect with a cable rather than wireless. Ensure printer drivers are installed in control panel/program control and check device is registered in device manager with no exclamation/question marks next to it's name
1helpful
3answers
Canon pixma mp499 is offline how do I fix it?
Make sure that it's powered on. If it is, then it sounds like it's not on your network. Run the setup program and enter your wifi network information into it, so that it gets on your network. If you've already done that, try power cycling the printer. I have to do that with my HP wifi printer every once in a while. When it goes to sleep it drops the connection.
1helpful
Printer canon pixma mp495 multifunctional
Since you've already performed a Factory Reset, which ought to take care of anything along the lines of corrupted system files, you might want to double-check that you have the correct drivers. Canon Support Drivers PIXMA MP495
Once you have the correct drivers, try doing a factory reset on your printer while it is not connected to your computer. Once complete, try using the USB cable that came with your printer to connect it to your laptop and install the drivers.
There is the possibility that your printer, even after a factory reset, is trying to automatically use WiFi for its connection to your laptop. Assuming you're using DHCP and not static IP addresses, try giving your printer a static IP address, as it may be fighting with some other LAN device for a particular IP address.
If it turns out you do have the correct drivers and you are using WiFi for the laptop to printer connection, I would suspect something is wrong with the WiFi connection on your printer's side or in your router's configuration. Make sure you have the printer's MAC address in the appropriate table in your router's filtering configuration, if you're running MAC address filtering.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
1helpful
3answers
Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
4helpful
Why is my canon mp495 saying that it is "offline"?
Go to system settings and select the 'Printer' option. Right-click on the printer and enable the 'Use Printer Online' function. Cancel all the printing jobs till that moment and redo the process. Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue. Check all network connections and functions. Be sure the network interfaces work properly. Turn the printer off and on to see whether the device is working properly.
1helpful
Hi. I just bought an MP495. I went through and thought I'd ensured i'd set the wireless up properly, however my computer thinks the printer is offline unless the usb connects both machines can you help?
This should point you in the right direction...
Is this printer set for the default? have you rebooted? (Sometimes my pc needs a reboot to find the wireless printer)
Have you checked your hardware profiles to see if there are any error messages in the hardware profile?
Are you certain you have the right driver for the version of windows you are using?
Best regards
Ck
2answers
Printer says it is offline. How do I make it "online" once again? Notification it shows: "The printer is offline. Check that the printer cable is connected and the printer power is on." Printer cable...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi15
old marine
old marine
ZJ Limited
ZJ Limited
