Garden Logo
Posted on Jul 12, 2009
Belt change on a hydrostatic 265 John Deere
How does one replace the drive belt located above the PTO on a John Deere 265 lawn tractor? Thank you! Andy
  • Anonymous Mar 17, 2014
    Change ignition module on L110
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5063
Points
16
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
1helpful
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
2answers
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
John Deere 265 replaced pto switch on dash pto drive belt and mower deck belt still pto does not engage...also randomly blows 20 amp fuse from time to time when pto would engage previously...checked...
The electrical is part of the PTO clutch assembly. It should only draw 5-7 amps. Ohm reading is somewhere between 1.7 to 2.5 ohms.
These coils do short from anywhere from a partial short to completely.
Jul 26, 2014 • Garden
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Top Garden Experts
Jay Finke
Jay Finke
john h
