Kenmore dryer 400 series never stop when timed dry cycle even if the door open. Buzzer sound never stops at end of cycle.
Kenmore dryer 400 series does not stop when I open the door in middle of timed dry cycle.
Also, Buzzer sound never stops until I change the timer knob position to off.
Do I have now 2 parts broken?
1,Door switch (Timed dry cycle never stop even if the door open)
2,Timer (Buzzer sound never stop until I switch to off position)
Can you please determine what cause this issue and what parts do I need to replace this time?
Should I replace the timer first and see buzzer issue will fix or not?
Please advice,,
Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
Unfortunately this sound's like a faulty timer. Most of those 80 series Kenmore's have the buzzer/end cycle signal built onto the timer, that added to the issue of the timer continuing to advance past the "off" position indicator, I'd suspect a timer.
You should check with Searspartsdirect or partsdepot etc. as well as any other local and on-line part's supplier on available new or rebuilt timer's. Often rebuilt timer's are just as good for half the price of a new one.
Hope that help's. If so please give a rating on the info I provided to you here at fixya.
Thank's for using fixya and come back if you need further assistance.
Good luck
macmarkus:)
could be a number of things, but you may want to test with an ohmmeter if you have one. It sounds like your timer needs to be replaced. If the buzzer is not shutting off, the timer may not be turning to the off position. It may be really slow our out of wack, not letting the dryer completely dry. It also could be an error with the dryer's control module (kind of like a computer for the dryer) I also recommend playing around with door switch, it to may be faulty. If the dryer does work with door closed, it is unlikely to be the door switch. You will have to test timer and door switch with ohmmeter or voltmeter to determine that the voltage current is constant and not speratic or shorting out.
buzzer is built -in the timer you all should replace it if you really want it solved they have done their work over the years. It's not something you can just go in and unplug or cut sorry. Good Luck. Post your make and model numbers next time please.
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
