If your Belling oven is unable to unlock after a power cut and you've already tried holding in the cancel button, there are a few additional steps you can try to unlock it:
Check the fuse or circuit breaker: Make sure that the fuse or circuit breaker that controls the oven's power supply has not tripped. If it has, reset it and try to unlock the oven again.
Check the lock mechanism: Make sure the lock mechanism is not damaged or stuck. The lock mechanism may have been damaged during the power cut.
Try resetting the oven: Unplug the oven or turn off the power at the circuit breaker for a few minutes, then turn it back on and try to unlock it.
Check the manual: Consult the user manual of your oven, it may have specific instructions on how to unlock the oven after a power cut.
Contact the manufacturer: If none of the above steps work, contact the manufacturer for assistance. They may be able to provide additional troubleshooting steps or arrange for a service technician to repair the oven.
It's important to note that these steps may not work for all models, and it may be best to take it to a professional technician for further assistance.
The issue you're experiencing with your Bosch convection microwave not heating in convection mode could be caused by a few different things. Here are a few things to check:
Check the settings: Make sure that the microwave is set to convection mode and that the temperature and time settings are correct.
Check the element: The bottom heating element is responsible for providing heat during convection mode. Make sure that the element is not damaged or burnt out. You can visually inspect it, if it is damaged it will need to be replaced.
Check the fan: The fan is responsible for circulating hot air during convection mode. Make sure that the fan is not blocked or damaged. If it is, it will need to be replaced.
Check the control board: The control board is responsible for controlling the functions of the microwave. A malfunctioning control board could prevent the microwave from heating in convection mode.
Check for a blown thermal fuse: A thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse is blown, it will need to be replaced.
Check for a blown thermal cut-off: A thermal cut-off is a device that cuts off power to the oven if it overheats. If the thermal cut-off is blown, it will need to be replaced.
