Why does the touchscreen keep tilting g upward each time I put my car in re else?
Each time I start my car, the touch screen tilts upward. The camera is on, but I cannot see it cease the screen is not facing me and I would have to turn the power off and it would go back in and stays there. When I turn it back on, tilts again.
To reset the moonroof, flip the ignition switch to the "ON" position. Then, press and hold your moonroof's button towards the full-tilt position. Repeat that step a second time once the moonroof is tilted upwards. After getting the moonroof to tilt upwards a second time, hold the button for an additional four seconds.
May 9, 2018
To reset the moonroof one-touch operation:
With ignition switch in the "ON" position, do the following:
1. Push and hold the "TILT UP" side of the switch until the moon roof tilts all the way up and then tilts down slightly (approximately 10 mm [0.39 in.] at the rear).
2. Check for proper operation of the "one-touch slide open/close" and "one-touch tilt up/down" functions by pushing the switch briefly to the "SLIDE OPEN" and
"TILT UP" positions.
mine had done the same thing what it is is the silver peice that your sim card slides into gets wore out i had taken a little peice of paper and doubled it up put my sim card in and put the papr bahind it it has worked ever since
Just press the soft reset button at the bottom of the phone with the stylus. Make sure you use the stylus because I ended up damaging my mic with a paper clip.
