Ovens Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE MODEL JGBP oven lighting is intermittant. - Ovens
Anonymous
Level 3:
  • Master 1,136 Answers
  • Posted on Jul 11, 2009
Anonymous
Master
Level 3:
Answers
1136
Questions
0
Helped
354252
Points
4025
Hi, If this is a gas oven, you will need to change the ignitor. This is a very common issue with gas ovens. The ignitor is getting weak and not opening the gas valve as fast as it should.
Please let me know if this helps you or if I can assist you further.
Vic
GE Cafe Dual Oven Gas Range - CCGS990SETSS - Bottom won't light intermittently
CALL A LOCAL SERVICE COMPANY GAS PROBLEMS WE DO NOT ANSWER THEY TEND TO BLOW UP
Nov 03, 2021 • GE Ovens
tip
Ge profile oven probe and bake lighs flash intermittently
<P> </P> <P>unscrewed probe housing, insured  black/white wires were secured to connectors and re-installed housing.  ( white wire was not  fully seated into connector Lights no longer flash.<BR></P>,
on Aug 20, 2013 • GE Ovens
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
We have a GE built in oven, model # JCKP13GP-1. The oven, after operating for an hour or so, shuts down. Sometimes the signal beep goes off when this happens but not always. Any hints on what this could...
We see a symptom like this sometimes due to a failure in the electronic clock/control. Although, by the time we get the control in for repair, it is usually shutting down after a minute or less. You could also have an intermittent temperature sensor or intermittent wiring to it or the door lock, so you should consider that first. The control board for this unit has been discontinued, but we repair them at www.fixyourboard.com.
Sep 30, 2009 • GE Ovens
1helpful
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 • GE Ovens
3answers
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
