SOURCE: Not getting cool enough
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
try moveing the thormister up in the refer it is on the right hand side of refer inside refer box if this does not help use a fan and blow it tru outside vent on low
SOURCE: dometic rm2350 - cooling in
Corrosion can form between the pipes and the fins inside the fridge.And this causes the problem.
If you are a bit of a handyman,turn off the gas and take the bottom outside vent off and remove the whole burner assembly at the base of the fridge. There is a metal cover that shields the burner but It is fairly straight forward, just be careful once the burner assembly is removed to NOT loose the gas jet that is a little dome like cone inside the end where the gas pipe goes in.
Carefully clean the jet with metho solvent to unblock the jet orifice.And do not poke anything in the tiny jet hole.Then try if it works and cools properly on gas.More that likely the control board has gone bad or the thermostat quit working. You might have to try and light this on gas several times to finally get it to go, if there is any air in the line it won't light and the air must be purged. This can take several minutes of continuous trying to get it to light. When it kicks off switch from gas to off and back to gas again till it lights. Have you checked the thermocouple that lets the control board know that there is fire in the pilot? If this is bad it won;t kick the main gas valve on. You can check these with a volt ohm meter, when there is fire on the thermocouple you will get a small voltage reading in the mil amps portion on the tester, no reading means bad thermocouple. Check the fuses on the circuit board under the cover I mentioned on the back of the fridge. You should have access through a door on the outside of the coach.----------------
If not then Do a direct test on the cooling unit. You will first need to locate the 110Volt heating element on the rear of the refrigerator. It is located in the tin stack on the right hand side. After locating these two wires, you must plug them in to a 110 Volt source. You can do so by cutting an old extension cord and splicing the wires to to the heating element wires, then plug the extension cord in. This will by pass the thermostat and run your cooling system wide open. If your refrigerator works in a direct test then the problem is your thermostat. But if still not running then problem is with mother board(the main board of the unit).Also, you can replace the OEM electronic motherboard with a better made 3rd party board made by Dinosaur Electronics, who make quality replacement boards for less cost then original. They are not difficult to install.As you mentioned its not cooling the fridge on any 3 way source,this indicates board problem.------------------ This should help.Thanks.Helpmech.
SOURCE: DOES NOT COOL AT ALL ON GAS OR ELECTRIC
I have a NDR 1292 that does not cool on gas nor electric.
The coils do not get hot at all. Inside, the control board lights up and operates...just no cooling.
I see an answer on this page that says bad board...what board? the one inside at the top that has the settings?
Help?
