I have Kenmore Elite Bottom Freezer fridge. I noticed the freezer filled with ice and after awhile the water leaks out of the freezer.
SOURCE: FF200EP Fridge Freezer - water
I had the same problem, the fridge would leak overnight (usually) I found with some more searching the answer..... try it at you own risk!
Here are 2 detailed answers depending on your circumstances/technical ability....Turn off fridge....
1. Defrost fridge...catch all the water
or
2. Work quickly....
Remove drawers, at the back of the fridge there is a panel with 5 phillips screws (note that there are long and short screws). Remove the screws and the panel. (if you chose the second option then this will be "frozen in place" so you will get crunching noise when you peel it away - so be careful when removing it). At the top of the panel is a connector that powers the fan, squeeze the 2 sides in to remove. This will allow the panel/ducting to be removed from the fridge. (If you chose option 2 you will now probably see a large lump of ice over the drain hole).
Remove ice or debris from drain hole, re-asssmble not forgetting to connect the fan again!!!) then repower the fridge following the instructions as you will get the alarms... the fridge cools and the warning lights dissapear.......24 hours on mine is OK!
Mal Function
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
SOURCE: Water leaks into freezer bottom & floor
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
