Automatic repair is initiated in case of windows corruption due to malware and viruses. it may happen due to incomplete updates and improper shut down.
you need to run the repair. if that does not work, then you will need a windows expert (technician) to work on your computer. call 1-877-805-1027 .. a reliable tech support company that will not scam you or charge too much.
SOURCE: computer recieved the blue screen of death but before....
turn it on with a/c and remove battery if it starts normal then the problem is from battery (TRY IT I HAD THE SAME PROBLEM)
REPLY THANKS
SOURCE: blue screen acer 5517
Boot into safe mode and use System Restore. You have to try several dates.
It sounds to me that the MBR (Master Boot Record) maybe corrupted. Sounds alot worse than it really is. If the laptop is failing to repair itself then you will have to find the original discs that came with the laptop that contain the original shipped OS files. If there were none when you purchased it, the pc would have prompted you to burn them upon the first boot up. You won't lose any of your data by utilizing these discs to repair the boot record.
