The 280 is a solid machine. It has been in use in the corporate world for several years. the 5000 has more expandability. However both are underpowered for gaming. but the 5000 would be basically the same speed as the 280 but you can put 4gb of ram in the 5000 and only 1gb in the 280 so the you would get more speed out of the 5000. I would however recommend you get something in the win7 product line as this equip is about a decade old and built for win XP which is obsolete and no longer supported.
I think you would be much happier not to mention safer on line
Testimonial: "Actually, I've got 4GB in my 280 addressing 3.25 with XP-86 - really wanted a 'real-world' benchmark comparison, were I to pull out the 280 system RAM and use it in the 5000, with everything else the same - probz should've made myself clearer on that; Aside, I'm pretty sure you can put 2GB max into a 280 SFF (mine's a desktop); I just want to know if it's worth shifting my 280 hard drive & 4GB DDR2 into a 5000 shell - would there be any advantage? Can't find a bar chart between 280 and 5000 anywhere..."
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Testimonial: "Sorry didn't ask for specs, wanted more of a 'real-world' benchmark comparison - should've made myself clearer I suppose... #NotYourFault"
the drive can be xferred the memory won't it the wrong speed
