Hi, i have problem when using the YN622c, YN622c-tx and YN565 EX II flash. The problem is the HSS doesn't work. My camera is Canon EOS Sl1 100D The HSS settings is visible in camera menu, the HSS icon is visible on YN622c-tx display and also on the display of YN565 EX II speedlite. However when i do a shot with time speed higher than about 1/250 i see the black strip on the photo. Every other features work like expected - triggering the flash, setting zoom, changing power..etc only the HSS doesn't seem to work. Interesting is when i use the speedlite directly on the camera (without YN622c triggers) the HSS works without problems - i can take pictures up to 1/4000 without any black strip in the photo. Could you give me some advice, how can i get it to work? Can it have something to do with voltage? (i am using Eneloop 1,2V rechargeble batteries) Can it have something to do with firmware version? (Haven't try any firmware update yet) Thanks in advance. Tomas
SOURCE: LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
SOURCE: Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
SOURCE: Powershot A460, LCD picture is black but display options appear
Have you tried pressing the Display button on the back?
SOURCE: flash not working on Sony Cyber-shot dsc-p100
this has happened to me a few times and all you do is make sure you take out your memory card, push in the reset button for about 3 seconds and it will work again!
