Ovens
come in many varieties including freestanding units and stacked models
that are inserted into a wall. Kitchen oven units that get a lot of use
or are getting old may have problems develop, such as a loose or
squeaky door which may require replacing the hinges. You can replace
the hinges on the door to your oven by first removing the door from the
rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Difficulty: Moderate
Instructions
Things You'll Need:
Step 1
Open
the oven door and examine the hinges to see how the they are secured to
the door. Some oven doors slide into the hinge assembly or have a
locking mechanism that secures the door to a latch on the main unit.
Step 2
Remove
the door from the oven by disengaging the locking mechanism and then
pull the oven door out. You may need to release a catch on the door or
remove a pin from a hole in the hinge.
Step 3
Place the door on a flat surface such as a table or the floor.
Step 4
Remove the screws that hold the sections of the door together to access the hinges.
Step 5
Remove
the hinges from the door. The hinges may be attached to the door with
screws or they may be held in place when the door sections are
tightened or secured.
Step 6
Insert
the new hinges into the door and secure them with the screwdriver or
place the section of door back on. Tighten all of the screws securing
the sections together.
Step 7
Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
