Ryobi 24 in. 40V Lithium Ion Cordless Hedge Trimmer RY40610 Logo
Juan Carlos Rios Posted on Jul 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Battery is fully charged green light but when i pull the triggerit doesnt work i use it all the time no problems before
jim heidy
Level 2:
New Friend:
  • Expert 41 Answers
  • Posted on Jul 12, 2015
jim heidy
Expert
Level 2:
New Friend:
Answers
41
Questions
0
Helped
16189
Points
116
Look for reset button and push it look in the manual it may help
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jim_c09d8140f32619a8
My batteries for both lawn mower and wiper snippet have green lights saying fully charged but will not work on either are the batteries stuffed
a good routine is to purchase a battery tester. hold the tester on and see if the output drops after a period of time.
Usually Batteries (when used) only uses a certain amount before they are charged..
When this happens The battery is only using the same cells within the battery & NOT using the full battery potential.
When this happens The battery life shortens & When charged The battery Will Indicate Fully charged But The Battery Life Is Reduced Because they Way it has been used & Charged. Always Use a Battery From fully Charged to Almost Flat Before Fully charging your battery. Also Don't be afraid of Over Charging your battery when it indicates Full. But not Too Much... Maybe an extra Hour or 2 tops.
Only amber light flashing continuously and battery meter gadget shows the full battery but laptop does not come
Buy a new battery, may show as fully charged but does not output to laptop, i had same problem bought new battery fault solved.
Samsung sl605 wont turn on
A charging battery's light is red. If it turns green then it means it is fully charged. Since you had stored your battery for a while, try to charge it by using a battery charger to kickstart it. It should work. Whatever transpires let me know. thanks and rate this answer.
1helpful
3answers
I have a 18v battery charger for my great neck drill but the red light insant lighting up when I go to charge my my battery, but the green one is lit up.
Try jump starting the battery. Li Ion batteries often have smart chargers if the battery gets to low the charger doesnt recognise it. If yo have a spare battery fully charge it ant then conect + to + and - to - with wire ( may take two people) kep them connected for 2 mins or so then try in the charger.
Worked for me
3answers
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Gun will not fire, battery is charged & good ??? model #IM25011 part # 900400 Bob
problem solved - battery charger indicated that battery was charged with green light on, took battery ouit & placed it back in charger & red light came on after doing this three times the battery was fully charged and the gun worked fine.
thanksBob
11helpful
2answers
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
6helpful
2answers
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
