I have a new Samsung dvd player hooked up to a Sony TV and cable box. When watching DVDs or Netflix at some point during the show the TV screen goes black but audio remains. Any ideas? Someone suggested the machines are having a hard time shaking hands.
SOURCE: Loss of Picture
You can use this firmware too:
http://www.samsung.com/us/support/download/supportDown.do?group=mp3audiovideo&type=hometheater&subtype=hometheatersystems&model_nm=HT-X40T&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=03030100&disp_nm=HT-X40T
SOURCE: How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for service...it was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
SOURCE: Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
SOURCE: No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
