If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Search the site by type in this keyword "Double image, mirror image" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Just a shot in the dark but the first thing i do when i get a blurry rptv in my shop is clean the mirror. Dust can accumulate and create a blurred image. You must be careful however as some of the mirrors are Front Surface mirrors and require special cleaning solutions/techniques. If thats the case using a damp cloth could ruin the mirror. I hope this was helpful.
It must be the LCD faulty.you have to check with a good LCD. If not suceed, need to check the cable connectors.If not solve change the flex cable & check
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
