I've read through the posts, cleaned the mesh/filters, entered diagnostic mode (no error codes), tested the values in diagnostic mode (both hot and cold work as expected (water pours into the washer), but when it washes/rinses the water comes in as a dribble (both hot and cold). Oddly enough, when you change the water temp from cold to cold/warm when the washer is filling, the water pours in like normal for a second and then goes back to a dribble. I would greatly appreciate any ideas or wisdom on this. Thank you in advance!!
Thank you, Ilia. The fill valve is not plugged up. In fact, when I turn on the cold and hot valves in diagnostic mode they work as expected. It is only while the washer is in operation that the water trickles in. Is it possible that the valves could be bad if they can work in diagnostic mode but not when the washer is actually washing? I welcome any thoughts.
Check your fill valve if it is plugged up or sizzed up
If
your washing machine will not fill, only hot or cold will fill or is
slow to fill then read these tips. I have covered many of the things
that can happen in these tips...
Washing
Machine Problems No Water
Washing
Machine Fix Washing Machine No Water
heatman101
