I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
Dado
Temperature (Celsius)-----------------Resistence (Ohms)
55 ------------------------------------2960
50 ------------------------------------3570
45 ------------------------------------4330
40 ------------------------------------5280
35 ------------------------------------6490
30 ------------------------------------8030
25 -----------------------------------10000
20 -----------------------------------12555
15 -----------------------------------15880
10 -----------------------------------20260
5 -----------------------------------26080
0 -----------------------------------33870
Dado
As you can see this is NTC thermistor is with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
SOURCE: how do i change the heating element in my dryer
it's way to hard afor a lay person,call for repair-mike
SOURCE: whirlpool duet not heating, replaced thermistor
If it just won't heat, it's a thermostat issue (most likely). You can try a different setting and check if it works. There are different thermostats for different settings. Also there is a contact that is operated by the motor to insure that the drum is turning for heat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: My bottome dryer wont heat up but the top dryer heats
I have the same problem and called a repair center to fix. They came out last Thursday and and ordered the parts (thermite and thermo fuse). Waiting for a call that they received and ready to repair.
SOURCE: my dryer is turning but not heating. How hard is
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
SOURCE: My Dryer is turning on
The problem is a broken drive belt or it has slipped off the idler pulley. Disconnect power then remove the rear access panel and reinstall the drive belt over the motor and idler pulleys. If the drive belt cannot be reinstalled from the rear access panel or if it has been broken and needs to be replaced, you have to tear down the dryer from the top to the front panel.
Remove the screws attaching the to panel to the rear of the dryer then slide the panel rearward and off. Remove the screws holding the control panel to the inside of the dryer cabinet then lift up and roll it forward. Remove the screws securing the top of the front panel to the cabinet then lean the panel forward and disconnect the door switch wire harness. Lift up on the panel and set it aside.
Remove the front bulkhead then take the drum out through the front. Install the drive belt around the drum then over the motor and idler pulleys. Put the dryer back together in reverse order of the tear down process.
