SOURCE: I do not have a internet connection on my tablet
I wish ur tab does't hav cellular data conection or its not supporting.
SOURCE: Ho do i take music and pictures off my trio axs 3G tablet because my screen is broke in the top half
connect it to your computer with usb cable and copy files to your computer it should ask you when connect it what you wanna do or you can use my computer or start menu to browse the tablet and select files to copy to the harddrive
SOURCE: Bought a ematic 7" HD quad core tablet screen crack bought on 12-24-2015 is it still under warranty
if you bought it at a shop, take it back, its the sellers responcability to sort out a replacement/repair/or money back first, then if you get no joy then contact the manufacturer
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet
manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attemps.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
SOURCE: I would like to know is the (trio:) quad core tablet 7.85 8GB 4.4 blue tooth compatiable?
yes its compatiable
Testimonial: "Thank you, I just have to see how to make it work. thanks again."
