SOURCE: Region Code
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
SOURCE: v ipod mode in Samsung HT-Z420 home theater system not working
Plug a yellow video cable into the TV (IN) and the Sound system (Out) then go onto AV1 on the TV or which ever port you plugged the cable into and play a movie and u can see it. A menu doesnt come up like the A ipod funtion so it comes up no signal until u play an actual movie on the ipod. If u dont have a yellow video cable i think u can use the white or red audio ones.
SOURCE: Samsung Home cinema HT-TXQ120 system won't read CDs and DVDs.
Hi.
I have had the same problem.
Just unplug the systme and plug it back in.
