Available parts and illustrations handy for home repair can be found here:
KENMORE DRYER Parts Model 11087873100 Sears PartsDirect
SOURCE: gas dryer will not heat
The dryer will not heat i check the vent to make sure no upstruction and open the back to make sure no wire was lose. where will the fuse be kenmore model 76722697 serial No. 0702383
SOURCE: kenmore gas dryer is not giving out heat
Check the fuse and control thermostat on the blower housing. They provide power to the gas assembly.
If all of that is good then check the flame sensor. If the flame sensor is open then no power will get to the then the common wire to the coils and ignitor will be open causing no heat. Read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
SOURCE: kenmore gas dryer no heat
Hi Steven
I hope this help U to fixya your dryer's problem
http://repair2000.com/norun.html
Was this helpful?
SOURCE: Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
