Front door willnot stay closed - Whirlpool Cabrio WED5500X 27" Front-Load Electric Dryer with 7.4 cu. ft. Capacity, 9 Drying Cycles, 4 Temperature Settings, Wrinkle Shield Plus Option and AccuDry Sensor
you will need to take it to the local service center, they will do the required work. mostly u will have to get your body changed as the lock that holds the battery cover is a part of the outer body of the camera
Not worth repairing,DVD players very cheap these day.U can get a brand new one $40-$50.Times, parts,and labors cost u that much to change the motor.By the way ur motor that control the DVD tray is dead.Best just buy a new DVD Player.
If you mean your cdrom drive wotn stay close, what can happen some times is the actually cdrom unit it self has shifted back inside its rack. try opening case and loosing a few screws here and there and shift it forward. make sure nothing has got stuck inside of door tiny bit of paper or anythign can cause it. hope this helps
no... raise the front of fridg a very little untill door will stay closed all fridgs are a little higher in the front that way when the kids don't close it properly it will close by it self........
Your oven door has tension springs. check to see if it came off on the side with no tension. If you have a bottom drawer, pull it out. You should see the spring underneath.
you did not mention what type of machine you have, but, sounds to me like you have a fuser problem. With a Canon ( which is what it sounds that you have) you need to open the front door and press a service switch on the left by the counter and see what the code is.
