I can not get the phone to work with the base phine and the slave unit. It has been charged to full but on the screen it says "to register HS see manuel." What manuel, none came with it. My original tha came with the three phone unit does not tell me how either. Can yoy help.
SOURCE: Diigital answering machine and 3 portable phones
Here is the link for the manual; http://www.vtechphones.com/docMgt/public/art/20411/ip5850-man.pdf Page 23 - flashing CL means you need to set the clock. All explained there I think Hope this helps :)
SOURCE: Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: Battery won't charge - Charging light won't come on.
did you chk the charger adapter working fine?
SOURCE: bought new phones kxtga110ex and want to register handset from kxa141es
I can send you a manual. Just email me on [email protected]
