I did a little searching and found a few pages that may be of help to you.
How To Unlock My Tablet if Forgot the Unlock Pattern
How to unlock android tablet after forgetting pattern lock
There were also a few videos I saw on youtube, but the ones I looked at, used software I am unfamiliar with. If you wish you can always look for those, if you are still having trouble.
I post on behalf of HP.
SOURCE: Hi...my goibii 7inch tablet is locked with a
look for your tablet on the internet and find the lock overide sequence keys
Hi, you will have to factory reset! Follow these instructions:
A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The Cruz logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen.
B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A.
NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button.
C.) In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
