the LCD Display has been cracked, there is no way to fix this without replacing the LCD display which in some cases is as expensive as a new laptop. I'd suggest taking it to a screen repair professional and getting a quote on a replacement screen and compare that with the price of a new laptop.
Check the connection at the back of the TV. During moving, any of them might got loose. Check it. As the TV has snow and hissing sound, there is no fault with it. The fault must be to the cable or antenna connections.
During the start up press the escape key (in case of not responding try the tab key) in order to remove the logo and see the report on the screen. What are the 2 last line reporting?
Waiting clarification, don't hesitate to post.
Thanks and regards Please kindly rate this solution Stelios direct FixYa link: http://www.fixya.com/users/technical114
had the same problem had the main powerboard replaced they were out of stock and had to send mine in and vizio referbed it I was told it was a common problem with this unit
If you are sure that it is connected right and tested the audio inputs because to do that you will need an original remote, then you have a bad tuner or input switcher IC and no I am afraid that the TV most likly is not worth fixing. Good Luck
