Epson printer printing blank pages, when you have an empty ink cartridge, outdated printer driver, printer print head missing, improper ink cartridge installed, and more.
Follow the steps to fix the Epson printer printing blank page issue:
·Restart the Printer ·Fix the empty and damaged ink cartridge ·Clean the dirty printer print head ·Update the printer driver
It's not going to work until you replace the empty cartridge.
I haven't heard of any printers, colour printers, that will print
if ANY of its cartridges are empty or missing.
This can be caused by a number of reasons however it is mostly caused by the toner cartridge missing a small spring on one end. Try replacing toner cartridge first.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it. If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty. Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life. If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads: -leave the printer on for a day -run several head cleanings and print the nozzle check pattern -if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer. -reinsert the cartridges -run one head cleaning -wait about an hour then run some head cleanings. -dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Try to print something that is pure yellow and pure black. Set it to BEST PHOTO. If you see gaps or missing lines, your print head could be clogged. You will need to use a cleaning solution to remove the clog.
Even with out the Black cartridge installed the X1240 should use the color cart to make a "composite" black. I would suggest calling Technical support to troubleshoot that issue ad get you to test the cart itself
Try doing nozzle cleaning, hope fully this flushes the air bubbles trapped in the cartridges. Or try using this template which sometimes flushes out the inks.
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed.
When you next change ink you will have to repeat the above procedure.
