A manual for the thermostat is needed to recalibrating if doable, thermostat model number and brand needed to get the right manual.
A thermostat mount location should be planned. Any holes leading into the wall should be sealed, in other words, the thermostat needs to be insulated and isolated from fake temperature readings, no back drafts or not heat or cooling sources near by.
SOURCE: furnace-not heating all rooms to set temperature
Depending on where your living room is in comparison to your furnace it could be just that the fan doesn’t have enough force to get it there so what is happing is that all the other air is reaching other rooms before it. There are products that can help with this u can find them at larger hardware stores they r inline fans that go in the ductwork or there r a flat type of fan that mounts on the vent and plugs into a wall outlet that will pull the air to that room the latter would be much easier but it is your choice. Hope this helps.
SOURCE: Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
SOURCE: My central ac system occasionally
I have seen this is many digital thermostats. The worst problems usually come from the touchscreen thermostats. I would suggest installing a new thermostat. Make sure that you read the instructions before you even remove the old one.
SOURCE: danfoss thermostat control frozen at
See the link on the Danfoss site. This has helped me http://heating.consumers.danfoss.com/xxNewsx/5dbcb2f9-e888-4d2d-9761-7470786749c9_CNP1.html
SOURCE: thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
