Mower picked up a piece of chain, disengaged the mower and dislodged chain pieces. started mower the mower started normally but the mower was not moving. after awhile I started it again and barely moved slowly. Now does not move. Engaged the cutting part and works properly.
Ck belts that run hydraulic pumps for tire drive , it might have slipped a bit with chain caught , now belts skid instead of transferring power to pumps , also these pumps might have a manual pressure relief reset , I was thinking they only used them on bigger units , but you might have one as well ,hey its possible , this will need to be reset prior to continuing mowing (refer to manual for location )
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
SOURCE: I have Model YTH2548 riding
When you raise the front or rear of the tractor, and push on the belt (engine off of course), is there a lot of play or slack in the drive belt. At this point from what I have read, the issue is the drive belt, and is slipping when in gear and when it heats up. The next thing to do would be to replace the belt, but I not sure if this procedure is an option for you. When you inspect the under side of the tractor, and inspect the moving parts and pulleys, if any of these components are in need of replacement, you will be able to tell by either rotating them manually or visually inspecting them. At this point due to the low hours, I suspect the drive belt is stretched out, and is considered a maintenance replacement part procedure.
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
