OUr phones were working fine but we could not speak or call anyone so we bought new batteries. Now there is static on both our Uniden phones and cannot hear or speak over the static!
SOURCE: I have a uniden dect
Hi, I have a dect 2035 and began having the same problem. I don't know how the feedback came about but it was suddenly there today when I tried using the phone. After mucking around with one of the handsets I hit the speakerphone button and turned the volume all the way down, it only goes down to a preset minimum, I then turned speakerphone off again and turned the volume for regular handset mode all the way down too. The phone works beautifully again!
SOURCE: Static on my pair of Uniden cordless phones (Model DECT1560)
Is your base near a computer or other electronics? Also, make sure your microwave is not on. I get static if I do any of those things.
SOURCE: i keep hearing an echo when i speak into my phone
some phones have a natural problem with this due to the electronics in the handset others may have a button that says channel or scan this will allow the handset to look for a stronger channel between it and the base most of the time that will cure the problem. if not hang up and try your call again it will allow the base to do the same thing and may clear the problem up. nether helps you may have a defective phone.
SOURCE: Static interference on Uniden 5.8Ghz phone
i have a uniden 5.8 ghz cordeless and thought it was a piece of junk as well. I had static or lapse of audio near the router, the kitchen sink, the microwave (even when off) and in the doorway. I switched the frequency on the router and changed the channels on the phones all with no luck. Short of steering clear of my entire downstairs nothing worked.
Just about ready to buy a new phone and hit up google. Saw a posting that said to keep the base away from even the tv. . .hmmm this is exactly where mine was located. So I swapped the digital answering machine base and moved it downstairs and put the additional base near my flat screen. Guess what? Problem SOLVED! I still cannot believe it.
Hope this helps
SOURCE: I have a Uniden set of of phones - 5.8 GHZ. Both
• Keep the handset away from microwave ovens, computers, remote control toys, wireless microphones, alarm systems, intercoms, room monitors,fluorescent lights, and electrical appliances.
• Move to another location or turn of f the source of interference.
