Apple iPad (16 GB) WiFi Tablet PC Logo
Posted on Jun 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ipad 2 will not charge - Apple iPad (16 GB) WiFi Tablet PC
  • Chris Dunning
    Chris Dunning Jun 26, 2015
    Hi rochellewar, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    First, have you tried charging with a different cable.
    Second, how are you attempting to charge your iPad? Are you using the power adaptor (that plugs into the wall) that came with the iPad, plugging it into a computer, or using an adaptor other than the one it came with?
    Third, have you tried using the cable you are using on a different device (like an iPhone or another iPad)?
Andi Kovaci
Level 2:
New Friend:
  • Expert 40 Answers
  • Posted on Sep 14, 2015
Andi Kovaci
Expert
Level 2:
New Friend:
Answers
40
Questions
Helped
6343
Points
119
Check the plug
check the cable
if all are okay
need to send your iPad to the service
Ipad will not charge
You will need to buy a new charger because they wear out pretty quickly
My iPad 2 won't hold a charge
Bad battery pack. Suffer with it, or buy a replacement.
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
2answers
My apple ipad wont charge or turn on
With iPad Magic, you can transfer photos, videos, music, books, etc. between iPad, iTunes and computer at ease. Moreover, it also enables you to convert audio and video files, rip CD and DVD discs, download online videos, make ringtones and more. Also, it works well on iOS 7 and iTunes 11.
http://www.youtube.com/watch?v=8ALYybIAL3k
Supported iOS Devices:
iPad, iPad 2, The New iPad, iPad mini, iPad with Retina display;
iPhone 3G/3GS, iPhone 4/4S, iPhone 5, iPhone 5C, iPhone 5S
My iPad 3 battery is charging slowly how do I speed it up?
Make sure you are using an authentic charger if that doesn't help update your ipsw to the latest firmware
3helpful
3answers
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
