Has been working, but no power tonight. Fuse box in the house for the machine had tripped. Socket it is plugged into is still working, so wondering if a fuse exists in the machine and where it is
Electronic is protected against short circuit throught out VDR - voltage dependent resistor which is located on the electronics. Unfortunately, when this happens usually get hurt some other component part or burn printed circuit boards.
Any intervention on electronics requires qualified person otherwise there is the risk of fire or electric shock.
Dado
SOURCE: AEG Favorit dishwasher fault
check time delay function - press til '0' appears or repeatedly til all time delaying diodes do not light
SOURCE: when switched on the machine trips the power.
Is it tripping the breaker in the breaker box? If so you have a short to ground. Could be A bad spot on the dishwasher cord. Turn power off and pull dishwasher out and check the power cord all the way back to the dishwasher terminals
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
SOURCE: My AEG dishwasher - Favorit no. 60870 sensorlogic
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
SWITCH THE POWER OFF FIRST
